I have a large 1 ohm
If i hook 1 side of the resistor to the positive side of my power supply and the other side to the B+ terminal of the amp.
And the negative of the power supply to the non-bridging speaker terminal
No remote applied
I twist the transformer every which way i cannot see it spark at all .. All lights are off in the room
No remote applied
That should be OK.
Connect it in series with the B+ line. Ground the secondary center tap of the transformer. Make NO other connections to the amp. Twist the transformer and look for sparks. Continue doing this until you see the exact point where it's sparking.
insert an insulator between the windings at that point. If it's on one of the terminal windings, Insert a piece of thin cardboard coated with adhesive.
I got this pic from amp guts since im waiting on my new camera to arrive..
I grounded this lead of the transformer and ooked a resistor to the B+ twisted the transformer and cannot get it to spark at all..
The lead has the blue line going to it in the pic
Then it appears that the short has been eliminated. You should try to force it to short again so that you can determine the point where it's shorted and insulate it. If you leave it as it is, it's likely to happen again. If it does, it could damage the head unit, the amp or the vehicle (if the shield ground in neither component opens).
Are you sure that the resistor isn't open?
- General Interest
- Car Audio
- Hifonics XX Chaos
