Hifonics Sampson
I REPLACED THE OUTPUTS IN THIS AMP ALONG WITH THE DRIVER IC'S AND A 330 OHM RESISTOR ON THE DRIVERBOARD.
WHEN TRYING TO POWER THE AMP UP THE RELAYS CLICK ON FOR A SEC THEN CLICK OFF AND AMP GOES INTO PROTETION.
IF I REMOVE THE OUTPUT DRIVERBOARD AMP POWERS UP BUT THE GREEN LED DOESNT LIGHT WITH OR WITHOUT THE DRIVERBOARD.
ANY IDEAS ON WHERE TO CHECK?
Heres a pic of the driverboard
Back to this amp again.
I replaced all outputs and let the amp sit for awhile now when i try power it up it draws excessive current.
If i disable the output section amp powers up fine and idles around 5 amps.
I checked all outputs in the amp they all tested fine I also have the output driverboard removed.
Any thoughts on where to check or do i need to take all outputs back out of the amp and check for leakage?
