hifonics hurcules xx
Im working on a hifonics hurcules xx amp. I checked all power supply fets everyone is toast, checked the outputs almost all are toasted and checked the diodes which are toast also a resistor is toast stillmeasures 10 ohm but badly burnt. Wondering what else should i check out in the amp Is there something common whith theese amps to blow alot of stuff like this ANY help would greatly be appericated
With class D amps, using a different part will often lead to trouble. Sometimes, even a replacement with the same part number won't work properly. If, for some reason you need to use subs, you should repair it with the original parts, confirm that it's in 100% good working order and then use the substitute. Then, if there's a problem, you know it's almost certainly due to the sub.
After you get the amp working, you need to check the drive signal on the gate leg of EVERY output transistor. This amp has eight different drive circuits and, if I'm not mistaken, will operate with as few as two of the eight in good working order. I've seen several that had multiple dead drive circuits.
ok i just recieved the outputs and power supply fets. Somemore checking on the amp the rca jacks are broke also there are 2 orange parts behind the rca jacks that look like mylar caps they are marked 222 but they are 3 leaded parts does anyone know what theese parts are and where i might be able to get them any help would greatly be appericated
