Hifonics Brutus
Hi All.
I have a question about this amp model BXi 2407D
I got after trying to repair and replacement of transistors stageout power.
Are all the transistors should be IRFP640N? 2x6 pieces
There should be two pairs? IRFP640/9640 ?
What should be the original transistor control? ( Q284, 285, 286, 287 and prefix'A )
Maybe someone has a diagram or photos of the interior is to locate the transistors
Thanks in advance
Lee
Thank you for your reply Perry
I thought that it obtains from you a satisfactory answer.
On the tip of the power transistors, I'm 12pieces, 6 items per page in the following 3 items were listed on page 3 x IRF960N (original) and 3 x IRF960N (solder - shared) - and the same on the other side - I wonder whether they should not be a P-channel (3 pieces swap-soldered to the page)
Maybe someone had Hifonics'a in mono in his hands and took some pictures inside ....
Waiting for other speeches.
In the evening, accompanied by photos of the amplifier.
Regards.
Lee
