Hifonics Brutus BXi2006D
I received this amp for repair.
The amp powers up, idle is stable, its not in protect and it produced audio.
Someone has attempted to repair this amp and didnt do a very good job. Although its working I question its reliability.
I am going to reflow the solder on the p/s fets and gate resistors.
The amp is missing 2 outputs, my question is this amp has all IRF640 in it with no IRF9640. Is this how this amp is suppose to be?
Before I replace all the mismatched date coded output fets I want to be sure this amp uses all Irf 640's in the board. I thought they would be IRF640N and IRF9640.
I am beggining to wonder if its even a BXi2006D or a smaller amp in the wrong case??
Can anyone tell me if this amp has the correct outputs installed? I would think if you had IRF640's where the 9640's should be it wouldnt power up???
I have posted a pic of the board can anyone tell me by looking?
The board number is SMB-045-90 2006.12 REV:0
I reflowed the solder to the p/s fets, replaced all the outputs, and removed an un needed jumper someone installed and this baby rocks the old 18.
Is it fairly normal in these amps for the audio driver board to run pretty warm?
What causes them to run so hot?
Can the circuit be modded or something added to dissapate some of the heat for added life besides the heat spreader?
I will have to e-mail you for the heat spreader, I dont have the tutorial yet.
