Hifonics Brutus Bxi 2006D in protect
ok it would go into protect then removed driver board and would power up fine so had another driver board from another hifonics amp, identical to the original, installed it and would power up fine, then all of a sudden it would blow my 10 amp fuse when powering up checked output transistors in board and legs 2 and 3 on right bank of 6 would read 0 Ohms in circuit found the 2nd fet to be bad other 5 check good but what could cause excessive current draw even if the fets and driverboard are removed, ive removed 6 of the fets, and it powers up fine but seems to draw more than normal current, when i install just the driver board back in circuit it goes back into protect
Vias are the copper feed-throughs that connect the traces on one side of the board to the traces on the other side of the board.
Are either of the other two shorted? If not, there may be an open connection between the drive circuit and the gate of the FET that was preventing the FETs from switching off.
the other side checks fine , here is Q203 of the bank what it reads out of circuit, will post other 2 as well
