I recently bought a T1 amp and now have it all set up and working with a SMPS300R. Out of curiosity I checked the DC offset and found that the right channel was within the specified 0 - 10mV but the left channel was way out, over 200mV. I attempted to adjust it but found that the voltage was steadily dropping off by itself. After a few minutes it had dropped to 100mV. If I set it close to 0mV with the preset pot, after a while it's dropped to a minus value or out of range 😕
There's also audible hiss on the left channel whereas the right channel is silent. Even with no load the heat sink on the chip gets quite warm. Is this normal?
I wonder if the chip is faulty or if there's another explanation for the noise and the weird behaviour of the left channel DC offset.
Any comments most welcome as I'm a relative n00b when it comes to the technicalities of class D amps.
Steve
P.S. The amp works OK and sounds excellent (apart from left channel hiss).
Steve
