> Is power transformer 15V with 200mA for LME49720 enough?
Did you read the datasheet?
Look at page 5, IOUT and IS. 12mA to live. 20+mA of load current, if needed, but in audio less than half the time. So 20mA max per chip. 40mA for stereo. Double the DC current to shop for an AC Amps rating. 80mA. You may find that you can't buy a respectable transformer that small.
Thank you, now I understand what to check in data sheet next time.
Another very good question and that's addressed in nearly all authoritative literature. Earlier, I mentioned Walt Jung's Op-Amp Cookbook. Carefully read the first few chapters. There are many other good sources too, not only Jung. Another good source are the op-amp manufactures' application notes.2) I have for amplification R3 / R2 + 1 values 10000/680. Why higher resistance is usually used? What will happen if the resistors will be just 100/6.8?
In a nutshell, more or less, the choice of low or high resistor values is a tradeoff between several factors that come down to stage noise, input offset current management, and circuit layout leakages.
Yet, his question was simple and direct: why not "just 100/6.8" 🙂
Book is downloaded and ready for reading before sleep
Still trolling my answers. There's an important trade-off in the selection of feedback and input resistors based on acceptable noise and input bias current. One cannot simply reply with "100/6.8" as answer. Care to explain what effect a 100 ohm feedback resistor has on the load impedance?Yet, his question was simple and direct: why not "just 100/6.8" 🙂
IC op-amp Cookbook
I think some other people would like to read IC op-amp Cookbook by Walter G. Jung too. It was little bit difficult to find it, but it is here.
Last I knew, Jung was not allowing most of his books to be published. Do you have his permission?
Things changed. It is also available on archive.org - OCR scan with spelling errors (yes, OCR is not perfect). I do care about copyrights. If it would be illegal, I am not sharing this book.
Link to Walt Jung books from Walt Jung
[url=https://ebooks.waltjung.org/]Directory listing
that has a link to:
"2005 Op-amp Applications Handbook" that Walt Jung edited
Op Amp Applications Handbook, 2005 | Education | Analog Devices
that has a link to:
- Analog Line Level
- HiFi preamp LME49720 - amplification 10x?
