To play high resolution materials like the 24bit 192KHz Studio Master it is necessary an USB to I2S interface to drive any DAC chip.
I have contacted M2Tech to produce this module with this specification:
http://www.audiodesignguide.com/M2TO...ov-08-2009.pdf
If we will arrive to 100 items they can produce and sell this module at 50 euro each.
Please add your member id in the following list and update the total:
2 x audiodesign
now the total is 2
2 x audiodesign
now the total is 2
Hi Andrea.
very interesting GB 🙂
HiFace OEM is available in four models :
part.no. M2TOEM-01-1 is Bus powered
part.no. M2TOEM-01-2 is External 5V / Filtered bus power
part.no. M2TOEM-01-3 is External 3.3V + 1.8V
part.no. M2TOEM-01-4 is External 3.3V + 1.8V / Filtered oscillators pwr
M2TOEM-01-4 is the most flexible, external supplies for +1.8 +3.3 and Vosc (+3.3).. does Marco (m2tech) require a single model for this GB?
Ciao
Valeriano
EDIT : Guido you're faster than me🙂
Ciao
Valeriano
The lack of galvanic isolation is an issue IMO, possibly enough to negate the benefit of forgoing SDPIF. Just know that Ayre uses optoisolators in their asynchrous USB DAC. I think we should push for it if we can.
Ayre uses TAS1020 (Gordon Rankin/Wavelenght) that is limited to 24/96.
Back in this thread (#147) you'll find that it's impossible to galvanically isolate USB 2.0
Yes but who needs 24/192, better off limiting it to 24/96 and having a quality I2S, obviously Arye went for SQ over marketing specs, we push for the same IMO. No ones USB input beats the $2500 Ayre, this won't come close without the optoisolators.
I own a hiFace, I'm interested, if I understand well is to extract I2S from hiFace, If yes I have several questions:
-Where will be connected, between the port USB & the hiFace?
-It's only a chip or is a finished product like the hiFace?
-I agree version 4 is the most flexible but can operate without external psu?
me 😀Yes but who needs 24/192
AVHub - Hi-Fi - News Articles - North Star Design USB dac32 new competitors on the market (BTW Marco of M2Tech is the former designer of North Star Design, you bet what's in the box?). They claim ground decoupling, I don't know how it's possible.better off limiting it to 24/96 and having a quality I2S, obviously Arye went for SQ over marketing specs, we push for the same IMO. No ones USB input beats the $2500 Ayre, this won't come close without the optoisolators.
Ah, but this is not DIY, so I don't mind hehehe
Guido
P.s.: Merlin: I am sure you are aware of some good shunt regs...
It is possible, there's just a bandwidth limitation with the ADuM. I don't know if anyone has tested it with hi-res yet.
Audiodesign, I'd certainly like one, thanks very much for organising this.
uP interface... very nice!. Same question as above: any model or all orders have to be a single model?
+1
Definitely interested.
Btw, there is talk about isolation using ADuM on the datasheet posted above. 😉
mee too
Sound like a very interesting device. I would buy two as well if it comes to it.
Cheers, Tristan
Cheers, Tristan
- Group Buys
- Hiface USB -> I2S 24bit/192Khz
