For sail
HiEnd Power Amp with ready Holton modules
310W/8Ohms Holton with TOSHIBA Lateral MOSFET Output Stage amplifier dual mono
Two modules HPA-nxV500 VFED (HOLTON)
310 Watts RMS into 8 Ohms
550 Watts RMS into 4 Ohms
860 Watts RMS into 2 Ohms
Biased into Class A/B
Bandwidth 3.5Hz to 500KHz -3db
Dampening Factor 1300, 915, 248, @8 Ohms @100Hz, 1Khz, 10Khz
RCA Single ended Input impedance 20kΩ
XLR Balanced Input Impedance = 40kΩ
Single Ended Input Gain = 28.1dB
SNR -105dB
THD+N = 0.005% @ 10 watts 8 Ohms
Slew Rate = 90Volts / microSec
Power supply 220-240V with two 800VA toroidal transformers
60Ampers 200Volts Ultra-Fast Soft Recovery Diodes
50.200uF electrolytic capacitors in each channel (CORNELL DUBILIER, Illinois Capacitors, and SIEMENS).
Soft start system due to total 1600VA power.
Input Voltage 220 – 240 Volts
All assembly materials are the best in the market with Van Der Hull, Kimber cables, FURTECH XLR inputs,
MODU (Italy) enclosure with a 10mm aluminum front panel anodized in black color.
The amp is a monster of power with driveability the most power-hungry loudspeakers.
Dimensions: W450 L430 H190
Weight: 30 kg.
I send in all Europe countries (not in America, Asia, Australia due to very heavy parcel)
Price 1300€ plus 100€ transportation in Europe.
Tasos Architektonidis
demiurge30@yahoo.gr , Athens, GREECE
SNR -105dB
Weight: 30 kg.
