HI-VI M4N 4" for full range duty
Landroval said:
The M4N is no fullrange. If you look at the responce graph you can see it's ok for a midrange, but anything over 5000Hz is impossible to fix. The 1,5k bump can be tamed with a passive filter.
You should get the B3N instead:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-428
anything wrong with this tang bang?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-816
I know top end could be a little better... but it looks decent enough
Those spikes at the top look quite bad. The W4-655SA would probably be my choice for 4" Tangband, but I have to say it's not perfect, a noch filter is a must, and a super tweeter wouldn't hurt.
If you want something good you need to pay more (FR125S) or get a 3" (W3-817, NS3-193, B3S/N).
the FR125S is used in my other speakers... but not this one
it just needs to sound listenable... it's for a friend with poor audio tastes.... it just needs to be a 4"... just looking for the nicest solution for cheap that will offer OK sound
I will grab that W4-655SA... I can't find a place that sells them though 😕
