Hi! there, this semms like a good site to see if anyone can hepl me with a problam with my ROTEL RB-870BX amp, it was working great till i was hooking up new speakers and the wire got away from e and grounded or should i say "welded" itself to my computor case, now it still seems to work but no 'sound" checked the fuse and it seems fine the other thing i noticed is when shutting the amp off it used to a red "protection" light that came on for a sec or two now it does not, the tuner and preamp seem to be fine its the amp that is not functioning but does powerup, any help would be apreciated, thanks!
Hi. Welcome to the forums.
I expect that if you post your problem over in the solid state section, people will be able to help you. If you were to open up the case, and take some photos, we can help much quicker.
