Hi fonics Z-1000D
The power supply rails are likely regulated.
When the current demand increases or the voltage drops, the pulse width increases to maintain the target rail voltage. You can confirm that there is regulation if the rail voltage is constant no matter what the 12v supply voltage is (within the operating range of the amp).
The reference voltage is set on terminal 15. As soon as 16 reaches that voltage the pulse width will drop.
The regulation isn't capable of compensating for all input voltage. That why I stated that it maintains rail voltage for the operating range of the amp. The manufacturer doesn't likely include anything below about 10.5v.
