Hi. Thanks for reading this thread got a few ebay numbers here appreciate what you think of these boards, are they hi-fi? 273204156174 323552800636 142706692800 272560751990 123806213655 112148094209
How is this thread different from the one you created a week ago?
And please, to help others to answer your questions and see the boards, could you copy and paste the direct links?
The amp boards are totally different
Here are the links
Assembly K1058/J162 Pure Class A Field Tube Parallel Mono Amplifier Board New | eBay
UPC1342V 2SC5200 2SA1943 220W Mono Power Amplifier Board Kit HiFi Class A Amp | eBay
Assembled UPC1298V mono amplifier board class A power AMP 80W | eBay
A-30 Pure Class A High-current FET HIFI Mini Amplifier Board (2 Channle) 30W+30W | eBay
One pair assembeld Class AB Power amplifier board base on FM-300A amp L18-16 | eBay
https://www.ebay.com/itm/Assembeld-...094209?hash=item1a1c8c1d01:g:sm4AAOSwmfhX52JX
Here are the links
The last one (a variant of the JLH 1969 design in WW) looks most likely to get you closest to high-end sound in my view. I doubt that the others are really classA. Mind you, just having a nice stuffed board won't guarantee the best SQ, you do need to pay attention to PSU and ground and signal wiring too.
The reason i am thinking about those boards is that the layout is simple with few component parts and also the reason why i stared a thread on the lm3886 chip amp.
The length of the signal path is very short, people are suggesting this is good for sound quality. In fact with the lm3886 i could probably solder all the components onto the pins of the chip. The layout is so simple there are fewer variables to take into consideration and fewer ways it can go wrong.
Unfortunatly with the lm3886 and a lot of others they require error correction which complicates the layout excessively
What do you think of this minimalistic approach, is this a good basis for selecting an amp or have i got it totally wrong.
Will you also direct solder your DAC or preamp out to chipamp pins?
Sound quality should be superb then.
Have you built an amp before? It sounds as if you've been reading articles on "gainclones"? 🙂 An LM3886 amp is not a minimalistic approach, it just looks that way because most of the components are hidden 😉 They don't require error correction, much depends on the standard of performance you are after.The reason i am thinking about those boards is that the layout is simple with few component parts and also the reason why i stared a thread on the lm3886 chip amp.
You are correct: Point-to-Point LM3886
My only experience with LM3886 is with the cheap XY-kit, but for my ears it sounded ok. There were some complaints and at that time we lived in an apartment that had huge noise in power lines, that wasn't good for simple DIY power supply and amp. At the end I gutted the amp, but it got me interested in that chip.
Reading all the projects and comments, I've come to a conclusion that if I ever want to build a quality LM3886 amp, I might get my pcb's from Tom Neurochrome Audio: High performance DIY audio circuits.
There is also not so old thread about simple pcb design for LM3886, you should check that out also. An open source layout for LM3886?
If you want to buy some stuff from ebay, I suggest goldmund clone, they sound good. Maybe better than those class A you listed. Plus, no heat at normal listening level. PS is very important for class A, if you go that way.
Thanks, will keep looking at the goldmunds, look like good boards.
Opinions on these boards please
Musical Fidelity A1000 30W+30W Class A MJ15011 15012 Amplifier complete board 4650016144890 | eBay
Assembled PASS A3 Single-ended Class A power amplifier board 30W+30W DIY AMP | eBay
PASS F5 25w A class amplifier D.I.Y. | eBay
2x PASS A3 HIFI Class A Amplifier Board Single Ended Amp IRFP250 30W 8ohm 6010848620906 | eBay
https://www.ebay.co.uk/itm/1pair-MA...556416&hash=item3b0803492e:g:m~wAAOSwgSRbIJbJ
https://www.ebay.co.uk/itm/One-pair...296696?hash=item1c8db161f8:g:SZ8AAOSwUCRZiTEl
Any suggestions please
Sorry Master
I haven´t been diligent enough to fulfill your Order but am trying to get them all as soon as posible so I can test them side by side and offer you my humble opinion. 🙄
Any other Wish, Your Honour?
I was hoping someone may have purchased or heard anything.
Thanks for the master thing, that was cool and brave of you to admit.
I suggest you forget ebay kits, haven't looked at them, Chinese I'd bet!
I'd go with the Goldmund clone adason suggested. Don't expect Hi-Fi from anything else from China, I aso doubt you'll receive better advise.You should sincerely thank adason!
- Chip Amps
- Hi-fi amps or not
