Hi-End and Hi-Efficency loudspeakers (horn + onken)
I am searching fo this project a a 15" with
- a linear frequency band until 3-4KHz to prevent problem after the crossover frequency
- a moving mass no more than 90 gr
- a sensitivity near to 100dB
- a low resonant Frequency to have a good bass frequency band
I have found only the drivers analized in the webpage.
If there is a peak in the frequency response it is possible to esclude this only with 18dB or 24dB order filter because with a common 12dB this will keep in voice band.
All those things together? And perhaps also into a " cheap" woofer ? 🙂
Anyway, becoming serious, if you have a 100 dB- 15" with 90 gr or less Mms and with low Fs, automatically Qts will be low . Thus no (extreme) bass.
If there is a peak in the frequency response it is possible to esclude this only with 18dB or 24dB order filter because with a common 12dB this will keep in voice band. [/B]
Excuse me, why not employ a LCR trap instead ?:angel:
Paolo
Been there , Andrea.
Are you sure all those graphs are in the same measurements conditions? 😉
To my eyes some are 2pistr and others (maybe) can be 4pistr .....:angel:
Moreover Fs says a little if not coupled at least with Qts when you have to extimate F-3dB point.
P.S. : IMO Dr. Geddes is right, B&C are very good drivers. Unfortunately in Italy the price is .....not aligned with States!:bawling:
Paolo
Audiodesign your requests about the 15" woofer are simply impossible to satisfy. It is just about the laws of physics!
You are basically making a quite big mistake judging the linearity and quality of the speaker only by the on-axis frequency response.
You should look a least at the 30-45 degree off-axis response and the waterfall (CSD) and would see that none of those woofers is suitable for 3-4 KHz crossover.
Also you can see all those small peaks and dips along the impedance curve from 500Hz and above: each peak is a clear sign of break-up.
You really need to go for a 3-way speaker if you want an extended frequency range and real hifi reproduction.
The B&C 6MD38-8 is one of the few high efficiency midranges (96dB) with clean waterfall (very rare in high efficiency speakers) and flat frequency response up to the its first serious break-up at 5KHz. This speaker could work very well between 500Hz and 3KHz (using a series LC notch filter in parallel to the speaker and tuned at 5KHz in order to remove that resonance and make the cross-overing effective).
45
Also a very good driver. And not expensive.
Beyma 12br70
2X12br70
175L br 95dB 1W/mtr
-3dB 40Hz
-10dB 26Hz
100euro
Helmuth said:
I have another option for you. Very special driver for about 75euro
2X sph315 in one box = 2x 28cm with ferro fluid in airgap
130liter BR
97dB 1W/mtr
-3dB 45Hz
-10db 33HZ
sph315
If you look closer you will see that its down at 90db around 500hz, and then up again
So above 500hz its just useless
I would like to esclude parallel connection because I want an easy to drive loudspeakers with inpedance near to 8 ohm to the driven with any 2A3 or 300b amplifier.
Using a parallel connection of 2 x 12BR70 we can get a solution but the impedance will go near 2-3 ohm with the filter.
I am interested to a 15" to get a 35-3KHz linear frequency band but the filter will be positioned near to 800-1KHz
That is true tinitus only when you consider your room acoustics you know that a flat response is nice but will be disturbed by reflexions.
So I think this is a very flat response for a 94dB 1W/mtr speaker. And I ask my self if the response is the same in the box and with the balffle. Than can the dip can be gone or a raise some where else can occur.
So don't go blind on the graphic alone.
