I'm intrested in building a power amplifier kit equal in quality to hi-end amps such as conrad johnson and krell. Does anyone have suggestions?
Thanks,
Thanks,
fcel said:Even though Aleph series amp are not kits...
They are pretty much as kits now when people started selling boards and matched transistors sets.😉
By "equal quality" he probably meant same price range.😉
high end amplifier companies prolly
started out in the garage but
with pretty heatsinks/chassis
and marketing when it hits
commercial - hehe
commercial - hehe
Damn it Boaz you cut Nelson real deep! Let's hope Nelson Pass is a good sport and is going to forgive you !
I mean, you are talking to the real deal here, not just some "johnson" that doesn't even set foot in the shop, as such you should at least include Pass's products among the high end quality stuff you would like to achieve!
Sorry for that general question (Nelson).
I didn't mean just kit, it can be a design made by any of you which I can buy parts and assemble (Actually I think such a design would be better than a kit).
As a speaker DIY fan, which builds is own speakers, I'm intrested in building a DIY amplifier for speakers such as proac 3.8, for examining. I thought maybe you can suggest me such a design.
I thought that high end companies might sell even a lower quality amplifier than one can assemble by his own.
I'd appreciate your help.
Build one of the Alephs, either 5 or 2, although my recommendation goes for Aleph2 monoblocks. You can find enough info on this forum as well you can order PCBs and matched output devices. Using search option recommended.😉
You just can't go wrong with those amps and building something else wouldn't be wise.😉
The reason I asked is that some people want the
hardware of a commercial high end product and some
want the sound.
If you want the sound, then we have to ask why CJ and
Krell, since they are somewhat opposite sonically.
want the sound.
CJ
Well, I haven't listned to any krell, but have read that the pricey ones have great sound. A friend of mine, which have lots of experience with amplifiers and knows my taste, actully suggests me ones like CJ rather than krell. As I will use it for speaker testing I need a stable amplifier not like most of the tubes ones.
As for my test, I like natural, soft and "rounded" sound.
First I thought of a circuit of a known company design (like CJ), but I need your advice on what amplifier to build.
Thanks,
Thanks,
Update:
After reading some material over the forums, I think I will go on the Aleph2 as Peter suggested (Thanks, Peter). I now understand that Nelson is the designer behind it (Thanks, Nelson). I found a link to a site that sells exact PCB's for the Alephs. Where else can I find material about the Aleph2 (How to build, tweeking etc)? I've searched on the pass labs and pass diy sites and found almost nothing. Are there any other considerations (What kind of transistors, resistors etc?) I should think of? I do have background in electronics and I think I can handle the construction.
Any suggestions?
Any suggestions?
The parts and construction techniques for the Alephs
are not exotic. What you don't find at the Pass
web sites you probably will find performing searches
on this site.
on this site.
And don't forget to check out Peter's thread http://www.diyaudio.com/forums/showthread.php?threadid=3981 on bits and pieces of information on chassis building ... unless you already know how to do that sort of things.
Thank you all.
1. I reviewed some of the projects made, and I understand that the Alephs can be made using different parts. How do I know which are suitable for me? Are there any combinations that are recommended?
2. Are there any schematic differences between the projects?
3. Are 100W (idle at 300W) enough?
- hi end amplifier
