Going to leave this as To be continued, until i receive parts, i believe i just fried the IC, shorting it by accident... Once i get it, lets hope it fixes my issue... I'll keep you post it... I really appreciate the time and help. Many Thanks.
Hello. no, i shorted pins 7 and 8.. burned out Q2...Replaced IC 7500 and the Q2, now the green light turns on, now going to check the if it has negative pulse on pins 3 and 4. added jumper cables to board, to avoid slips or shorts ( will Try )
UPDATE : Got the amp to work... Thank you for you help Perry, you guided me to the location that i ignored, assuming that it was working properly. Thread can be closed.
