Hello,
Just build the Aperto (21 liters, tuned at 56hz) for the FR8c, and it´s sounding very good, with real bass, but a little bright on some records (around 20 hours of burn in).
So, I have a second pair of fr8c, and planning to build a beatiful,
tall(120cm)
wide(40cm)
thin(20cm)
enclosure for them, maybe simple BR, or a mltl or even better a Mileva or mini mileva?
I entered those dimensions on bassbox and get -3db at 50, tuned at 42
Any sugestions?
Really like the Mileva concept
Thank´s
tall(120cm)
wide(40cm)
thin(20cm)
Any sugestions?
Thank´s
fcj said:the FR8c.... or even better a Mileva or mini mileva?....
Demetri is the FE167/FE207/FR8 version of the Mileva.... if you would like the 1st draft plans mail me (we are adding a bit of depth and reducing the width to get a more aesthetically pleasing shap.... we will be building one set each for FE167 & FE207.
dave
PS: Scott was being coy... he modeled the verification for the design.
Don't judge too much until they've had more burn in. I'd pull 'em out of the cabs and put the drivers face to face and out of phase, then play low frequency sine wave sweeps through them at around their xmax for a day or two. Are you running any baffle step compensation? You'll probably also want some bsc in any BR. It'll change to tonal balance considerably.
pj
pj
Thank´s for the replys:
Not for the moment, what do you suggest as a start poit?
At what frequency?
I sended you a mailif you would like the 1st draft plans mail me
At what frequency?
Not entirely coy Dave. The ML MathCad sheets are only set up for circular vents. They'll model a slot-port OK, but if the aspect ratio of the vent exceeds 9:1 (IIRC) then their accuracy drops away a bit. That's why I want to do some more work on Demetri in the Sections sheet, to refine it a little.
Re: Re: Hemp FR8C in Wide and Thin (Mileva?)
1st "official" release of Demetri plans....
http://www.planet10-hifi.com/boxes-fostex.html#demetri
dave
planet10 said:Demetri is the FE167/FE207/FR8 version of the Mileva....
dave
- Full Range
- Hemp FR8C in Wide and Thin (Mileva?)
