Help with wiring
uni4VPvXO5p8
Jon's image behind several levels of indirection. (Samsung Cloud, at least.)
Too blurry for my eyes.
Interpret the schematic . I'm not that familiar with tubes and the pin s. I could become ting it backwards for all I know.Model Number: 6E2. Dual 6E2 driver boardX 1. 6E2 tubeX 2. 1x Amplifier Tube. DC-DC booster board:X1 (DC 12V boost to 250V adjustable). Notice: Copper column does not include..
To number the tube pins, look at the bottom of the tube socket.
Find the gap, or a notch, which is between pin 1 and the last pin.
The pin just clockwise of the gap or notch is pin 1.
The numbering increases clockwise (again, as seen from the bottom).
Some odd tubes are a little different (see the bottom views in the figure).
Be sure to use wire rated at the B+ voltage or higher.
