help with the AD1851
Hi, I'm looking for help with a project I'm working on using the AD1851 DAC. To test it I am trying to play a wav file that is just a tone but no matter what i play i just get a nonsensible output.
I am outputing to the DAC using a general purpose DSP from motorola that reads the flash memory and sends it to the DAC. I am sending the data at 7.5MHz which is within the 12.5MHz spec. Ive pretty much checked over everything including send MSB first.
I am using a timer interrupt that sends 16 bits every 22.727272us which is 44000Hz.
I think the problem is due to two's complement but for all i know it could be the timing in general or some other problem.
Thanks, Blazin
