C
CryingDragon
Do you think i could add another output pair to this to make it an even 500 watts or will the driver not have enough to power that many?,
http://www.mif.pg.gda.pl/homepages/tom/files/400MOS.gif
This really depends on how much the power supply sags at
500 watts. But there is plenty of drive for another pair
of output fets.
of output fets.
Mos transistors exhibit a purely capacitive input impedance at audio frequencies, and you can add more devices at the output in order to increase the intensity. But you have to increase the supply voltage too (carefully...)
The only problem is possible increase of distortion at the very high audio frequencies. You can cure this by increasing the current in the driver stage (which is low in my opinion) by decreasing the value of R15 (100, or 82 ohms) . The ordinary effect of this kind of tweak is better clarity, more velocity. It's important to install each pair of MJExxx on a little heat sink to avoid overheating, and some thermal distortion.
Regards, Pierre Lacombe
C
CryingDragon
thanks,i'm still learning amp design and everytime you guys temm me something like increasing the current thingy i remeber it and learn more 😀
You should ask the Saint (Anthony Holton), since he's the designer.
I've built a couple of these with IRFs and they work fine (even if I still only tested them at lower supply voltages, only 55+55V).
Now I'm gonna fire'em up with 70+70V.
Cheers
Andypairo😎
Cheers
Andypairo😎
