help with resistor
Hi all i am having trouble id ing this resistor i think the colours are white,orage,pink,red res (1632 x 920).jpg
thanks
If they are called C531 and C710, then they are likely small ceramic capacitors instead of resistors. Try measuring them as caps. Red-red-orange would be 22000pf, or 0.022uf. They will measure open on a resistance reading. COnsidering what they are, I wouldn't be surprised if they were really OK.
Your schematic shows both those call numbers as 0.022uf caps. In this case both are coupling two different sections of grounds within the amp.
Ah right capacitor ! (confusing this electronics ) well im learning,, would you mind having a look at the photo of the amp i have no sound output ,, i have tested the transistors marked with red arrows , also i have a audio signal generator but not too sure where to inject the signal to ,,would appreciate any help
Above post should have said voltages on pin s on the main SVI 3204 amp chip i have removed it and have a short between pins 2 and 11 i have traced the tracks back from these pins and checked the resistors which seem ok is there anywhere else i should pay particular attention to?
I have got a new chip ordered off "taobao" !! (chinese ebay) there you seem to be able to find anything you cant anywhere else ,,
here is photo of chip the short seems to lead back to this component not sure what it is though .chip (1632 x 920).jpg
very interesting assembly.
I think all the black numbered components are resistors.
I also think the brown bodied without ident are capacitors.
No smd transistors in sight. All in the two chips.
Is this an example of wafer level assembly integrated into smd?
Could someone with knowledge talk us/me through what we are seeing?
