Here's the schematic for one of the channels -->> http://home.swbell.net/acavalli/images/MJ_Headphone_Amp.gif
Here's the schematic for the supply -->> http://home.swbell.net/acavalli/images/MJ_Power_Supply_2.gif
When I simulated the plate supply (though without the 470K resistor as I can't put it) using Duncan's PSU designer, the the voltage across the last capacitor is around +200V. The load I used is a constant current of 27mA and this is according to the designer.
So I went and build the plate supply according to the schematics.
Well results are confusing. The voltage across the capacitors are:
1st = +350V
2nd = +350V
3rd = +350V
Can someone explain?
Maybe it's because that I need to build the amp first and connect it to plate supply and then I can measure the voltages across the capacitors and get correct readings?
Thanks for the reply.
Jayel
1st = +350V
2nd = +350V
3rd = +350V
Jayel
You're not loading the supply at all, so the voltage will be higher than the fully-loaded voltage. Simulate a load by figuring out what the expected current draw of your amp is and using Ohm's Law to calculate the equivalent resistor, assuming you want 200V at the output.
The usual warnings apply. The voltages here are potentially lethal and must be treated with respect. if you don't know EXACTLY what you're doing, DON'T DO IT.
