Dear guy's,
Maybe you have an idea ? about this,
I have a Philips cd960 But on some cd's (not all) I hear through the sound some static clikking noises.
I allready changed the laser and drive but it makes no difference. It is the CDM1 drive (very nice) by the way.
Do you have an idea ?
The laser is good it even reads cdr without a problem
and it is only on a few cd's that I have.
The clikking is also there when I use the digital out with a d.a converter.
Regards Muizel.
Regards Muizel.
The same model I have get for belt replace service and cleaning. after do this I observe the same effects as descripted here in post #1. After disconnect all internal connectors (both cable and modules) cleaning the pins and re-connect all unwanted audible clicking effects goes away.
Amazing for me by this compact disc player is the top quality circuit design regarded the reliability and the choice of electrolytic elements (Roederstein gold caps and ELNA). The best consumer compact disc player from Philips ever see !
In opposite to all the other models from that time like e. g. CD-100, CD-104, CD300, CD-73 (Marantz) and CD-303 no burned/overheated PCB aeras, no broken solder aeras and no dry/leck caps are to discover. What a mess. After cleaning and replace of the four belts you will get a player in nearly new condition.
BTW - the actually manufacturer for the PCB's and the loader-unit are the same than several models from the German brand "Braun" (e. g. the CD-4). Perhaps one of you knows this brand name - thanks for an advice.
on this forum I have found all this threads to the Philips CD-960 (CD960):
http://www.diyaudio.com/forums/digital-source/20964-philips-cd-960-a.html
http://www.diyaudio.com/forums/digital-source/47218-philips-cd-960-belts.html
http://www.diyaudio.com/forums/digital-source/88286-philips-cd-960-a.html
http://www.diyaudio.com/forums/swap-meet/133934-buy-philips-cd-960-spare-pcbs-chips.html
http://www.diyaudio.com/forums/digital-source/25689-philips-cd-960-transportation-screws.html
http://www.diyaudio.com/forums/digital-source/138589-cd960.html
http://www.diyaudio.com/forums/digital-source/97414-cd960-tray-problem.html
http://www.diyaudio.com/forums/digital-source/67081-philips-cd960.html
http://www.diyaudio.com/forums/digital-source/89200-help-philips-cd960.html
and here you will find some pics and informations:
http://www.marantzphilips.nl/index.asp?strPage=BrochureType2&strBrochure=Philips-cd960
http://www.marantzphilips.nl/index.asp?strPage=Info&strBrand=Philips&strType=Philipscd960
http://www.lampizator.eu/lampizator/REFERENCES/Philips CD960/philips high end cd player CD-960.html
ICs inside by CD-960
Follow PCB's and special IC's I have found:
Servo PCB TW-9094V-0: M80C51F-121 HC11017262 (Q271, OKI, MCU for Servo-Interface)
Servo Sub-PCB (SMD/SMT): 3x2902 (JRC), 2901 (JRC), D4030G, 4558, 4053
PCM Dec/Dig.Filter-PCB TW-9094V-0: SAA7220P/A (Q503), SAA7210P (Q501)
Main-PCB (PS+DAC): TDA1541
Front PCB W-2594V-0:
1) M2816A-30 (Eprom OKI, GF03)
2) M83C154-69 HC10016263 (MCU, OKI, GF01)
3) HC10015262 M80C051F-105 (MCU, OKI, GF02)
4) 2x LB1645 (Sanyo power buffer/amp for focus/tracking coils so as motor for disc and loader)
BTW - where I get software to clone such masc programable MCU's in general for all known compact disc player models?
The Marantz CD-94 (CD94) seems to be the same, at least by the most PCB's and loader/tray mechanism
Marantz cd94 cdplayer - Marantzphilips.nl
http://audio-heritage.jp/MARANTZ/player/cd-94.html
And the CD-304 MK-II use the same loader/tray mechanism than the model CD960
Philips CD304 mkII cdplayer - Marantzphilips.nl
more threads here about CD960 and CD94:
http://www.diyaudio.com/forums/digital-source/64941-cd960-belts-specs-service-manual.html
http://www.diyaudio.com/forums/digital-source/91833-help-me-mod-philips-cd960.html
http://www.diyaudio.com/forums/digital-source/74783-identifying-cd94-mk2.html
http://www.diyaudio.com/forums/digital-source/160558-anyone-compared-marantz-cd-94-cd-94mkii.html
http://www.diyaudio.com/forums/digital-source/148487-marantz-cd-94-poorly-again.html
http://www.diyaudio.com/forums/digital-source/60349-marantz-cd-94-sch.html
http://www.diyaudio.com/forums/digital-source/92740-marantz-cd94-doesnt-play.html
http://www.diyaudio.com/forums/parts/51572-marantz-cd-94-a.html
http://www.diyaudio.com/forums/digital-source/5166-looking-marantz-cd-94-schematic.html
http://www.diyaudio.com/forums/digital-source/104030-94-mk-ii-before-after.html (Modification Pics)
Belts (rubber strings) you will find about ebay item number: 380160949379 (CAS Service)
Belts for Loader A'ssy Marantz/Philips CD94, CD960, CD7, CD304-MKII and var. LHH's
I have study some service manuals for the Marantz CD-7 and CD-94
(Philips CD-304 MK-II and CD-960 uses the same Loader A'ssy)
Follow belts are necessary for loader A'ssy A001, used both for old CDM-2/CDM-4 and new VAM12xx mechanism units, Philips/Marantz loader part No 4822 691 10787 (482269110787)/355K304520+355K304510:
1) Belt 051M part No 4822 358 30762 (482235830762) / 167K264010 Motor M003
Belt from pulley 049M on motor M003 to pulley 047M (= pulley, clamperdrive 167K262020)
Belt with the shortest life time
2) Belt 052M part No 4822 358 30763 (482235830763) / 167K264020 CAM DRIVE
Belt from 047M (= pulley, clamperdrive 167K262020) to 045M (CAM, clamperdrive 167K054010)
3) Belt 025M part No 4822 358 30762 (482235830762) / 167K264010 (same Part No than 051M)
Belt from Pulley 021M on Motor M002 to Tray Drive Pulley
4) Belt 026M part No I find only from Marantz, No 167K264030
Belt from Tray Drive Pulley to Wire Wheel Pulley
Philips part No unknown, maybe identical with 026M from Marantz CD7 exploded view
part No 4822 358 31065/ 221K264010 go to
http://www.bgaudioclub.org/uploads/docs/Marantz_CD-7_SM.pdf
Belt sizes for Philips CD960/CD304-MKII/ Marantz CD7/CD94
I have found advices to the belt sizes: check out post #8 about
http://www.diyaudio.com/forums/digital-source/60588-marantz-cd94-belts-loading-tray.html
I read there the belt sizes (unfortunately without exactly informations about the position of each belt):
Qty 2 of 38mm dia X 1.2mm Sq section CPC-Farnell No AVBELT78
Qty 1 of 42mm dia X 1.75mm Sq section CPC-Farnell No AVBELT82
Qty 1 of 52mm dia X 2mm Sq section CPC-Farnell No AVBELT93
After size checking of the old ones from my CD960 I have for belt
replace service, I get follow (slightly different) results (refer also my post #5):
Qty 2 (instead Qty 1) of 42mm dia X 1.75mm Sq section CPC-Farnell No AVBELT82:
and
Qty 1 (instead Qty 2) of 38mm dia X 1.
2mm Sq section CPC-Farnell No AVBELT78:
Qty 1 of 52mm dia X 2mm Sq section CPC-Farnell No AVBELT93:
here the CPC-Farnell overview
Browse for Products | CPC
Here the PDF-URLs for service manuals:
http://www.nanocamp.de/manual/cd960.pdf
Marantz CD-94 | Owners Manual, Service Manual, Schematics, Free Download | HiFi Engine
and here some pics arround the loader and mounted belts:
in the attached pdf file you will find several extracts from the exploded view and mechanical part lists (from service manual CD960).
and
Re: Belt sizes
Sorry, I believe your information is not correct. The CPC-Farnell belts are nothing like the original, nor are the ones you checked. (Maybe they were changed?)
Here is more accurate information:-
Qty 2 x Motor belt, ref: 25M and 51M, P/Nr: 358-30762, Dim: 37Ø x 1.75mm
Qty 1 x Cam drive belt, ref: 52M, P/Nr: 358-30763, Dim: 39.5Ø x 2.4mm
Qty 1 x Tray drive belt, ref: 26M, P/Nr: 358-30903, Dim: 51Ø x 2.4mm
and
Datei nur auf Anfrage
I now have some 'replacement' belts from Classic Audio Service service@cas-germany.com. They supply:
Qty 1 x Tray Motor belt, ref: 25M, Dim: 36.5Ø x 2mm (thicker than original - this is probably a good thing, the old one was the cause of much slippage)
Qty 1 x Tray drive belt, ref: 26M, Dim: 51Ø x 2mm (very similar to original)
Qty 1 x Cam Motor belt, ref: 51M, Dim: 34.5Ø x 1.75mm (very similar to original)
Qty 1 x Cam drive belt, ref: 52M, Dim: 36.5Ø x 2mm (notably smaller than original both in diameter and thickness - little too small I think, I didn't use it - I wonder if it is a mistake, perhaps)
BTW, if anyone has some old stretched (not perished!) belts they want to measure, when you take them off boil them in water for a few minutes and they will tend to recover their original shape.
Today I changed the belts on two Philips CD960 players.
I used CPC:
AVBELT77 37mm x 1.9mm
AVBELT91 51.5mm x 2mm
On the tray lift side:
• AVBELT77 was good for the smaller 'motor' belt.
• AVBELT77 was good for the 'cam' pulley belt though it might be a bit tight and has to be stretched over the pulleys. This grips well and works well but I was mildly concerned that in time some wear may be caused to the pulleys around the bearing pins and so a slightly longer belt may be better in that respect.
On the tray sliding mechanism:
• AVBELT91 was good for the longer belt. Gripped and worked will with no slippage or squeaking.
• AVBELT77 gripped but the lowest point of the slider (that bolts to the wire and has the rubber buffer in front) overlaps this 1.9mm belt and jams causing the tray to be stopped. My fix was to use the Lindstrom oblique flush cutters and snip off maybe 0.2mm or 0.3mm of the rubber belts square edge so it's more of a triangle belt than square. This then cleared the slider and gripped and worked well. No stretching when under strain. Though if you don't have good cutters a thinner belt would have to be used.
To do it I removed the lid and bottom plate, the on/off switch rod, two cir-clips, the cam pulley, the tray pulley with the wire looped around but held it without letting go and moved the belt off and then put the pulley back on, so the wires loops stayed put and the spring stayed joined. Same for fitting the new belt but take great care to not get grease or oil on the belt.
I cleaned the pulley grooves with Isopropyl alcohol and 'kitchen roll' paper and a small flat screwdriver. With the belts off and the player on, pressing the tray button spins the motors for a few seconds. I used this to clean the smallest pulleys. Then the larger ones manually. Then fit the small belt and spin the motors to clean the smaller combined pulley and the larger ones manually. Saves some time. Be careful to not damage anything or short circuit the player or yourself! If you're not 100% certain that you'll not drop the screwdriver on powered up circuit parts then don't do it!
I cleaned all the old grease off the round rail and applied a very thin layer of 'white grease', I wipe it on with a small piece of kitchen roll as if I was cleaning the rod. Some types of grease on this rod clog and make the tray move slower. I don't know what the Philips / Marantz recommendation is for this.
On the other side with the plastic runner, I move some of the existing grease back into the path of the plastic runner or add a small amount of white grease.
At all times be sure to not get any grease onto the new belts.
I used CPC:
The tray bearing guide rod ('round rail') is not lubricated with grease. The tray runs on 'Oilite' sintered bronze bushings which are lubricated with a very small amount of light oil (and sometimes additional anti-friction additives) - no more that the porous bearing itself will 'absorb'. They are normally impregnated ('pre-lub'd') on manufacture. Grease should not be used, it is too heavy, will clog the bushings and cause too much 'drag'.
With the tray open I removed the tray pulley with the wire looped around it, but held it without letting go....
You can't do it with the tray closed as when it is, the wire from the back of the tray to the pulley is too short to allow the pulley to come off far enough.
Thanks 🙂'Oilite'...bushings...light oil
I used CPC:
Square section belts work in a similar way to V-belts establishing 'grip' between the side walls and the pulley on the drive side. It is not the intention to establish 'grip' by having a belt that is tight like a stretched elastic band. This is why the centre of the pulleys are usually 'undercut'. Hence it is quite normal to find one 'tight' side and one 'slack' side to the belt when in operation. In the same way as too much tension is bad for v-belts, it will also cause bearing wear and pulley misalignment with square belts and so is to be avoided.
I have yet to come across one player where the original belts were actually perished. Although I have changed belts occasionally for expediency I have found that I can always recover operation using the existing belts by proper meticulous cleaning (using isopropyl alcohol) of belts and pulleys. All 'dirt' must be removed. (I'm sure the same result could be obtained using 'meths' - I just didn't bother to try yet.)
Belts can be boiled in water to help them recover their original shape, although on some very old Denon belts where the unit (151A) had been untouched in a loft for 15 years I found the thick lower belt remained oval. The Denon motor pulley is small. But with just cleaning it was made to work properly.
So, before you change belts to some that aren't original, perhaps you should try cleaning. Don't forget the tray guide rail, if there is one. If it runs in plastic bushings it runs on grease. If it has small 'brass' coloured bushings then light oil - wipe it to remove any dirt and then just a touch of oil. No, not from the can, just a lightly 'part dampened' (not wet!) cotton bud/stick. If you can see oil flowing on the guide surface afterwards then it's too much - wipe it off!
Any unit that has sat unused for a while is more likely to show 'slow loading' symptoms. Unused for long enough and it may 'stick' altogether, at least in the interim. That doesn't mean it's 'had it'. 🙂
Yesterday I changed the belts on my CD-94. Rubber had gone in pieces, some had melted on the pulleys. So I had a bit of cleaning time.
I remembered IanAS suggestions and avoided to let the drawer spring go.
All in all it was a reasonably quick and cheap fix.
It could be the 'Horse shoe' board Philips blue electrolytic caps have failed, which is a common fault.I have a Philips cd960 But on some cd's (not all) I hear through the sound some static clicking noises.
http://www.diyaudio.com/forums/digi...s-cd960-cdm1-read-tracks-cds.html#post5128058
From thread title: Philips CD960 CDM1 does not read last tracks a cd's
- Digital Source
- Help with Philips CD960
