Help with noise reduction capacitor on old turntable
Hi all
I'm in the process of restoring an old Orpheus turntable. Its a Transcription type running an ac motor (Australian power 230vlt 50hrz?).
It has a little noise reduction capacitor (well at least that's what I think it is, see photo) that Isn't working (allows power through, so motor runs on or off, see pdf for how it was wired).
If someone could tell me what to buy to replace it, that would be swell? Or is there a better more modern (SIMPLE) solution?
Any tips on grounding would be also appreciated. Should I ground the platter separate to the deck. Platter doesn't touch the deck except for nylon bushes.
Thanks any input will be appreciated. I've been using this forum and others to find lots of helpful info, but cant find any on this.
  • IMG_0001.pdf
    IMG_0001.pdf
Thanks mate. Reckon thats it, actually I have no idea, but I'll give it a go.
I'll see how the platter goes ungrounded, it was originally grounded to the deck, cant see the logic in that, but hey there's a lot I don't know about turntable, but I'm learning.
Thanks again much appreciated.
I'm just going on the PDF that denotes it as a "Class X" no doubt it is some sort of safety/suppression type of cap.
The platter was grounded?
Hmm...odd, to me anyhow, I guess if there is some sort of noise issue you can try grounding it.
The capacitor is there to prevent sparking degrading the switch when turning off the inductive load (motor). If the motor now runs whether the switch is on or off then the cap has shorted, which a genuine mains-rated cap should never do. It may be that the original cap is a fake, or maybe it is not original but the result of an incompetent previous repair.
The usual problem with mains-rated caps is that they slowly reduce in value due to mains spikes burning little holes in the metalisation - they are designed to act in this way.
In this application any X or Y rated cap should do. The value is not too critical but don't stray too far from the original.
Data I stole the diagram from this pdf as it was easier than trying to draw one up myself.
Thank you for the explanation DF96, its likely I did something to the capacitor, maybe soldering too close .
So Data's second choice should do the job? Sorry just need to know what to get.
