Help with modifying passive crossover to active!
Using one amp for bass section, one amp for mid tweet crossed at 300hz with minidsp2x4hd. Keeping the crossover for mid tweet and would like to know which components to remove from the crossover since im sending only 300hz and above to the passive crossover below. I believe i should remove L2 and C2 on the scghematic, just want to make sure. Thanks in advance!
  • Schematic LE 109.pdf
