*2SJ74
*Toshiba Dep-Mode 20mA 400mW LowNoise pkg:TO-92B 2,1,3
.MODEL 2SJ74 PJF(Beta=92.12m Rs=7.748 Rd=7.748 Lambda=4.464m
+Vto=-.5428 Cgd=85.67p Pb=.3905 Fc=.5
+Cgs=78.27p Is=12.98p
+Kf=26.64E-18 Af=1)
*2SK170
* 20mA 400mW LowNoise Dep-Mode pkg:TO-92B 3,1,2
.MODEL 2SK170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Lambda=1.923m
+Vto=-.5024 Cgd=20p Pb=.4746 Fc=.5
+Cgs=25.48p Is=8.477p
+Kf=111.3E-18 Af=1)
+Kf=26.64E-18 Af=1)
*2SK170
+Kf=111.3E-18 Af=1)
bogdan_borko said:does anyone have spice models for these devices
that work good with CIRCUIT MAKER?
2sk170 / 2sj74
2sk1058/ 2sj162
bogdan_borko said:thanks a LOT! (boro care! PoZdrav!)
what about lateral mosfets, 2SK1058 / 2SJ162 ?
I'd like also to get working Lateral MOSFET models.
I use Electronics Workbench Multisim.
Besides 2SK1058 / 2SJ162, I want: 2SK1530 / 2SJ201
If anybody has got a good models of 2SK216 / 2SJ79 that works with Multisim.
I would be most happy!
I tried Netlist contributed 2SK216 model. I am sure it is good.
But I just get an error message. What am I doing wrong?
.MODEL 2SK216 NMOS (VTO=-56.0259M KP=20U L=2U W=10.3184M GAMMA=0 PHI=600M
+ LAMBDA=2.12826M CBD=1.80316N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0
+ TPG=1 UO=600 RG=50 RDS=1MEG)
Error on line 14 in C:\TEMP\02.CIR.cir: mu1 2 3 4 2sk216__mosfet_n__3
unable to find definition of model - default assumed
sawreyrw said:lineup,
The last quote in post #4 has a linewrap problem,
so if this is what your model statement really is, it won't work.
Add a + sign to the 2 line that don't have them.
The + sign means "continuation".
Model:
This is Error I get, running above model:
I don't understand. Is this really a linewrap problem ...
I don't think so.
lineup
This should help somewhat...
*SRC=2SJ76;QSJ76;MOSFETs P;Gen. Purpose;140V 500mA
.MODEL 2SJ76 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.48M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=444P CBS=533P CGSO=384N CGDO=320N CGBO=346N)
* -- Assumes default L=100U W=100U --
* 140 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
* 2SJ76, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
*SRC=2SJ79;QSJ79;MOSFETs P;Gen. Purpose;200V 500mA
.MODEL 2SJ79 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.04M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N CGBO=1.09U)
* 200 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
* 2SJ79, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
*SRC=2SK213;QSK213;MOSFETs N;Gen. Purpose;140V 500mA
.MODEL 2SK213 NMOS (LEVEL=1 VTO=15 KP=.16 GAMMA=18.6
+ CBD=560P CBS=672P CGSO=26.4N CGDO=22N CGBO=852N)
* 140 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
* 2SK213, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
*SRC=2SK216;QSK216;MOSFETs N;Gen. Purpose;200V 500mA
.MODEL 2SK216 NMOS (LEVEL=1 VTO=15 KP=80M GAMMA=18.6
+ PHI=.75 LAMBDA=521U RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=658P CBS=790P CGSO=26.4N CGDO=22N CGBO=852N)
* 200 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
* 2SK216, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
- help with models.
