Have a 800va transformer with two 60v secondary wires. Have two amplifier boards that use a single + 83v. What is the best way to wire these to utilize both secondary windings? Should i half bridge with two rectifiers running each board off each secondary and cap? Right now i have been running it off one secondary, rectifier to two caps in parallel and both amp off the positive 83v.
Can I make two positive 83v terminals one for each amp board? I know this is , just a hobbyist and want to make sure im utilizing my power supply to its full potential. Secondary is two yellow 60v leads. Thanks in advance for any help!
