Help with Linn Majik IP output Bias setting
Hi all, I'm hoping someone can help me with a problem.
I have just repaired a Linn Majik -IP Amplifier that had all output transistors blown along with numerous other components in the supply line.
It was that bad I think the previous owner had connected the Pre-amp pins the wrong way around and the thing went bang.
Any way the problem that I have is that I need to set up the new output transistors bias which is normally an easy job following the service manual instructions.
Unfortunately I cannot find any info anywhere on the net and my pleading with Linn and numerous other service centres came to a dead end as no one would provide me with the info.
I have attached a PDF with the Mainboard schematics but this does not mention the process.
Is there any way to set up this amp without the correct procedure?
Thanks in advance
Key
  • linn_pcas175_majik-1_mainboard_l13_rev.14_sch.pdf
Hi, thanks for getting back. I presumed that i had to set the bias as there are VR pots for both channels. In my limited previous experience these are use to set the output bias for the amp.
I have never come across a servo circuit before.
I haven't actually powered up the amp yet since i replaced all the blown components as I wanted to make sure any adjustments were correct.
Do you know what the VR's are for and do I need to do anything with them?
Key
