Help with GM Xtreme 7500 amplifier
The amplifier arrived with problems at the source and I managed to solve the problem with it however there is no wave generation to the output mosfet, I checked the driver card voltages and they are +12, + 5v and -5v, I changed the ir21844s and I still can't get the wave to the mosfet, any other suggestions please
Thanks for answering Perry
Thanks for answering Perry, I currently do not have a good camera, the photo I have taken of the driver card has been with the cell phone and I mark you in red the 2d transistors that are heating up, I changed them but I still do not generate the wave to the output mosfet, even before it had inserted an RCA signal from a 50 hertz wave generator and nothing yet. Any other suggestions
Well, Perry, I checked what you asked for and the square wave attached in the image is the one that comes out of tl072 and lm211, and the negative square wave of -100 volts is the input to the Ir21844s ICs and is the same in all no I had to test this before and I really don't know if it's the right one but in my opinion it should be the same as the one that comes out of tl072 and lm21, correct me if I'm wrong and if it's the reason why there's no wave in the mosfet output
Well I commented that the signal before taking the photo had measured it in the range with 5v / div taking the negative of the rail and showed me nothing, so far all the signal measurements I have taken from the negative rail with the range in I connect dc, and at the entrance of the ICs it shows me nothing only until I put 50v / div as I sent you in the image, for tl072 and lm211 with 5v / div if it shows me the square wave of output, my doubt now Is it at the entrance of the ir21884s ic should I find the same signal that comes out of tl072 and lm211? If I do not receive the signal, what should I check on the driver card to rule out the problem anyway when I arrive at the workshop again I will do what you indicate.
Good morning Perry, I did what you told me but I can't see the entrance signal in the ir21844s. I enclose the images of the result.
What do you think is the cause of the problem since in the eagerness to solve I returned and changed but this time all the integrated Ir21844, the tl072 the lm211 and the lm2903 since I do not have another driver board to test without result besides testing each other One the components inside and outside the plate.
Good morning Perry I apologize and you were right I was taking the capacitor's negative reading my mistake, now if I took the reading on the ir21844s from the negative rail whose voltage is -102 volt and gave me the input signal, I installed all the mosfet of output, I introduced a 50 Hz sine wave and the amplifier does not give me audio at the output, I put my probe in the coil before the transistors and I have no square wave signal that you think is the problem now
5v is a weak signal but maybe it's what pioneer uses. I don't have anything on a pioneer amp that uses 21844s.
With your black meter probe on the negative rail, post the DC voltage on all terminals of the 21844 IC. Copy and paste the following to post the voltages.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
How about Perry I come back to the workshop today after a few days incapacitated and the first thing I do is turn on the amplifier to take the measures you requested and one of the output mosfet exploded I found myself checking what could happen
I only connected it to a 12v low-amperage power source and in what turned on the mosfet exploded, it was precisely going to measure the voltages of irs21844 but it didn't give me time. I am currently only working the board, the amplifier is not mounted on the chassis and I have only installed a few mosfet to perform the measurements
Good morning Perry, these are the voltages taken with the negative rail.
Pin 1: 2.6 V
Pin 2: 0.3 V
Pin 3: 0 V
Pin 4: 2.6V
Pin 5: 0 V
Pin 6: 0 V
Pin 7: 11.9 V
Pin 8: 1.4 V
Pin 9: 1.3 V
Pin 10: 1.4 V
Pin 11: 102.5 V
Pin 12: 102.2 V
Pin 13: 102.1 V
Pin 14: 1.2 V
