help with gate drivers(IR2110)
Hey guys,
Well I'm trying to understand the function of a gate driver using the schematic below. How can I test the output of the gate driver without connecting the mosfets. Also will the circuit work if I just connect +/- 25V to the mosfets and -10V to the gate driver.
forgot to mention that I'am using an IR2110.
I just don't get how it works.
Need help
IR2110
Fredos,
Ok I've done my research and it seems the typical connection of a gate driver is to apply -VCC to pins SD,VSS, and Com. What does that have to do with it's function. Here is another example of a gate driver connection.
http://rl.pri.ee/electronics/amplifiers/class-d/version_3/index.html#output
Another thing, I don't have the load connected it to the output of the mosfets. So are you saying not to power the mosfets and apply the -10V to the gate and see the signals out
