Hi !
I need some help with designing a crossover for Accuton C92-6 and Eton Er4. Have found some on internet for Er4 but nothing for C92...Hope you can help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
speaker data can be found on...
http://www.accuton.de/e/data/products/c_drivers/C92/e_C92-6.html
http://www.eton-gmbh.de/dlstream.php?FileId=67
(sorry for my english)
Try this 4th filter ( very approsimative):
Er4: resistor series; 8,2microF series;0,16mH shunt; 8,2microF series; 1 mH shunt.
(Resistor 2,2- 4,7 ohm : listen!)
wf: 1 mH series; 17 microF shunt; 0,40 mH series; 3,7 microF shunt
+ Zobel CR (33 microF - 10 ohm) shunt. stop.
Zobel is deliberatedbly"overcompensated" , eventually try 27, 22, 15 microF. No problem .
Polarity: no one know if red is positive or negative . Can you measure an impulse response ? Otherwise try normal and reversed ( i don't know your offset ).
I hope you haven't doubt on wiring a "normal" 4tH passive crossover!
I know ER4 very well. Do not close rear face with a plate as a normal ribbon because it destroy the sound! A little rear box full cotton or dacron can absorb rear radiation (as come a cone midrange).
Hi!
Hi!
