Tony,
Is the crossover internal? If so, you hook the amp up right where it says on your panel. If it is external or you are biamping, you will have to remove the copper linking thingies and hook up the woofs and tweets separate as it also says on the panel. It's pretty straight forward. Are you familiar with biamping and such?
