Im still getting no power to the amp.
I replaced 2 resistors that were burnt but still not getting any power.
How should i trace it to find out where the problem is at.
Originally i had a semi conductor (the fairchild 75339) componant go out. I re sautterd that back on.
i also noticed that 2 resistors were out which i replaced as well they had a 5% tolerance. Im still not getting any power and i think it is due to that part 1nj0 100. Which i looked for on mouser using that part # with no luck.
Where should i start.
