in euphoniaaudio.com (http://euphoniaaudio.netfirms.com/e...id=66&osCsid=1bc1a7ecbf14e68439de5656195a8f48),
secondary4 is rated at 0-5v-6.3v @ 2A.
but when I read the accompanying PDF datasheet on the same page, I get feeling that sec4 is rated 5V @ only 1.5A. I'm not sure what is the rating at 6.3V.
can someone help clarify?
thanks for the help
thanks for the help
Looks like they made a mistake somewhere, because all the low voltage secondaries are stated to be 2A on the web page but only 1.5A on the pdf. You probably should contact them and ask for clarification.
If the 5v tap is 1.5A on secondary 4, then the 6.3v tap on secondary 4 will also be 1.5A (unless it's a very strange winding, in which case the 6.3v could be less than 1.5A - certainly not more).
ray_moth said:Looks like they made a mistake somewhere, because all the low voltage secondaries are stated to be 2A on the web page but only 1.5A on the pdf. You probably should contact them and ask for clarification.
thanks for the reply.
I emailed euphonia thrice but no reply at all.
They might Dont Know !!!
that hapends to me aLOT...
the stores dont know or care for what they are selling...
