Help with 5.1 diy setup
I will be building a small media room (length: 480cm, width: 280cm, height: 250cm) and i want to integrate a CHEAP diy 5.1 speaker setup. However the speakers must be build inside the walls (wooden structure in front of concrete walls).
The speaker cabinets must be as flat as possible, height and witdh dont matter. I will try different designs in winISD.
What do you guys think of this combination? -why mivoc? because i can get some of them cheap 🙂.
Fronts:
1x mivoc HG 258 G
1x mivoc WAL 416 4"
1x mivoc AW 2000 8" (passive)
Center:
1x mivoc KFT 130 M
2x mivoc WAL 416 4"
Surrounds:
1x mivoc HG 258 G
1x mivoc WAL 416 4"
Sub is for the future. The amp is 130w/channel and the room will be used for movies and games. Any advice? 😕
When I do a Google search, all I get are incomplete web pages and a warning from Google that they are not safe, then blocks me accessing any links, so you will have to post every driver's descriptions, specifications.
GM
Mivoc is ok, but what i don't understand is your choice of tweeter for the center.
If you want a similar sound from each speaker, than you should use in each the same tweeter. IMHO the KFT is ok but you can get better for the price 😉
A lot of guys will roll with their eyes about the following, but i achieved good results with the very cheap Tectronics BMR65. For effects from films and the quality of speech they are extremly good for the price. Needn't any crossover only a safety capacitor for my conscience.
ps a Hyperlink to Mivoc: https://www.mivoc.com/gs/index.php
No and no, but thanks anyway. The .pdf links were what I tried to access first, then went to 'home' and several other website's links, all to no avail.
BTW, this isn't the first time this has happened as recently there's been several European sites that I have accessed in the past, but can't now. Makes me wonder if 'big brother' has decided to illegally? censor us for our own good.
Anyone know if there's a way to override them? I have Avast!, Malwarebytes to [hopefully] provide me with adequate protection.
GM
