Help with 300b proyect.
A friend of mine who can build me a 300b SE amp has offered me his services.
I need a simple and good sounding design.
Is the Angela 91 amp a good design?
Is it better sounding than JE Labs 300b?
Are there better options than these considering simplicity/good sound
factors?
Thanks in advance,
Raul A. Fdez. Garrido
Xixon-Asturies (Spain)
Hi Raul
There have been at least two extensive threads on this issue, with exactly the same question and a myriad of answers, almost all different, by the way.
It is a drama, I admit. I am working on a reliable and technically good way to build amplifiers in a way that I can easily change tubes and circuitry, without having to start from scratch each time. It may take some time to complete it.
In the meanwhile I enjoy music from a commercial amplifier and a small headphone amp for late evening listening.
Erik
Hello!
How about this one? Of course the powersuply is a little complicated, or better said expensive... but you could use your own design: Legacy
The one I like the most, and it's very well documented is this one:
Karna
This one is going to be expensive too, due to the use of interstage transformers. But you shoul get excelent results. I would not wory for the tubes... excepting the driver and the output tubes which come with a price, the ones in the powersuply are very cheap.
Good luck!
Thanks, to all of you who contributed to this thread
I should also add, just in case there are some other piece of advice, that apart from simplicity/performance a non too extravagant budget is also appreciated.
Thanks Guys,
Raul
I’m about 80% done building my 2nd amp, a 6sl7/300B
I decided to keep things as simple as possible. For what it worth, here are some details
6sl7 in SRPP at around 360V B++
300B 300V -61V 60ma, about 370V B+ (classic config right out of the WE datasheet)
AC heaters for both, with the 300B cathode Res and Cap right on the 5vac trans c.t.
This is a slightly simpler config that the one you mentioned.
This is a design that has been done commercially in the past (Wavelength Audio)
