help with 3 tube reverb pot wiring
hi,
i de-soldered the 10ka pot to test a while back because i though the reverb wasnt working and now cant find the photo's i took of the wiring. the reverb was fine, i didnt realize its only connected to the 2nd channel. here is a diagram if anyone could help that would be great thanks.
i have labeled the wires A and B and the pot normal 1 2 3
Hello, the amp is a jansen 8/40. There's no scheme for the reverb circuit. I'm guessing because there is a cap between 1 & 3 and because it's only 10k it's used as a divider not a series pot so 1 or 3 is probably ground and a/b is each of the remaining two pins. When a/b are connected the reverb is on full, when a/b are oc the reverb goes into oscillating . I will just muck around with a few combinations of wiring till I get it right
