[Help] where I can buy DCB1 kit?
I might be able to help you there.
I have a DCB1 Mesmorize PCB arriving shortly that I no longer need.
I can also supply most of the semiconductors including the matched 2SK170BLs.
I have the OMRON 12V relay that is required.
That leaves only the easily and commonly available components to source. (ie IRFPs, resistors and capacitors) - You would also need a transformer, case and all the hardware.
I'm prepared to let the reduced kit go for £25.00 plus Postage.
You would get:
1 x PCB
2 x 2SK170BL (Matched)
2 x 2SK170BL (Matched) 10 in total
6 x 2SK170BL (Unmatched)
2 x BC550c
1 x BC560c
1 x BC517
1 x Relay
4 x BYW96 excellent replacement for MUR420
The only fun bit left is to buy approximately 50 LEDs and see if you can get four sets that meet the build criteria.
300 RED,GREEN,YELLOW,3MM LEDS | eBay
If you would like a comlete kit to make up the board let me know and I'll give you a price.
I will not be supplying transformer or case or hardware as these are items that are individual to each build, and easilly available around the world.
The Mesmorize PCB
This is the PCB on offer.
OK having been asked I have prepared a price for a complete PCB kit.
THIS DOES NOT INCLUDE TRANSFORMER, CASE NOR MOUTING HARDWARE.
It will include:-
1 x DCB1 Mesmorize BLUE PCB
1 x 50K ALPS Log B Potentiometer
1 x 6 Way Switch
7 x 12V OMRON G6H2 relays
7 x 1N4001 diodes
7 x 3 Way Input Headers and matching Sockets
1 x 6 Way Switch Header and matching socket
2 Pairs ( 4 in total) Matched 2SK170BL
2 x 220K RC55Y 0.1% Metal Film resistors
2 x 1M0 RC55Y 0.1% Metal Film Resistors
4 x 221R RC55Y 0.1% Metal Film Resistors
2 x IRFP240
2 x IRFP9240
16 x Suitable matched LEDs for voltage chains.
5 x 100uF 25V low ESR caps
2 x 4700uF 25V low ESR Snap in caps
17 x Non-Critical resistors for PSU and timer
LM7812 for timer
100nF non-critical for timer
BC550c's BC560c, 2SK170BLs and BC517 for PSU.
4 x BYW96
1 x AC Input connector
All BRAND NEW
£140.00 plus Postage. Theres nothing really heavy there so P&P should be reasonably low.
I've made a hiccup in the price above - But as I've quoted it I will take the hit.
This would just need a 50VA 15-0-15V transformer, a case and a little bit of hardware to complete. Apparently the bigger the better, I use a 60VA transformer with mine but 30VA is more than adequate until you start pushing the PSU into HOTROD territory.
Its not fussy about 15-0-15V either. If you have something bigger (say 25-0-25) it will still work but will just need a bit of heatsinking. The initial 4700uF caps also need to be rated to cope with any increased input voltage. Everyhthing else else should be fine.
Speak to me nicely and I can help you out with some of the hardware that you might need.
It will include:-
1 x 6 Way Switch
7 x 1N4001 diodes
2 x IRFP240
2 x IRFP9240
LM7812 for timer
4 x BYW96
All BRAND NEW
Please note that the price quoted is for BRAND NEW components.
What happened to all the initial interest ?
Please note that I am currently selling only the PCB, the 4 x matched 2SK170BLs, the 7 relays and the smaller transistors (all 10 of them).
Current price is £35 plus Postage.
The higher price was quoted when someone asked me to provide a complete kit for the DCB1.
