Help w/ Denon CDR W1500
Hi! If you own one of these maybe you can help. Having no luck getting an analog signal to show any meter activity despite: confirmed signal present at the units analog inputs, with the units input selected to "analog", the record/pause function enabled, "sync recording" OFF, and input level swept through entire range of -50 to +12db. The manual is very confusing. Is there a menu item I've missed? I can get meter activity with a digital signal. Denon's WEB site is of no help. 😕
