I have Yamaha AX10 professional loudspeakers. I'd want to identify woofers in use. They are 10", 4 screws. The magnet (which is not small) has a writing: "B10-120 100W 8<omega>". Probably, the main sign to identify is the cone. The cone (is done from paper, has dark gray color) is corrugated. An anti-dust cap has about 57mm diameter.
P.S. Probably, I mast add the cone is corrugated concentrically.
Thanks in advance!
Andrew
Thanks in advance!
Andrew
