Well, if you want to go to the D'Appolito design one could always build the Ariel TL designed by Lynn Olsen - that design has received consistently good reviews . . . For something simpler the ME2 should be good as well . . .
http://www.nutshellhifi.com/Ariel.html
LineSource said:Hi Simon5
The Trym has a 1.6Khz crossover point which allows integration with the W22EX001 22cm woofer. The W22 is one of the few speakers that has the surface area, and the Xmax, and the low Le motor to sound good from 30-2Khz.
I know one that is lower Le, higher Xmax, and more surface area, and sounds fantastic from 25-4khz... with slight equalization it can be bumped to 7khz
My friend finally decided to get the Onix Reference 1 Monitor because the av123 sold it to him at 450$ with shipping included with a 30 day free trial.
Not that bad for a 1500$ pair of monitors, even if the aesthetics aren't perfect...
I still want to thank everyone who helped me in this project. It will be delayed to a further date.
Thank you very much! 😉
