Help to connect powered mixer with amp.
Okay, I am in a bit of a panic. I need to throw a system together in the next couple days. I have a Peavey XR696F(2x600 Watts) Powered Mixer and would like to connect a Tapco J800. My hope is to use the 2 amps from the powered amp to run FOH and the Tapco to run a couple monitors. The XR696 has the following 1/4" connection:
Ft. Sw EFX Defeat, Line OUtputs-Monitor/Left Mono/Right,
Power Amp In-Left/Right
So that is 6 connections in all.
What I would I run from the Peavey to connect into the Tapco to get the setup I am hoping for? Here is a link to the back of the Tapco.
Picture Viewer
Any help on this would be much appreciated.
