I need some help sourcing 20x 47000uF 35v capacitors. The cheaper the better as I need a few. I am not too bothered about audio fidelity as I am after making a spot welder as detailed here Capacitor-discharge micro spot-welder construction
This guy has used 20 x 47000uF @ 35v to give 0.94F @ 35v. Provided the overall capacitance is similar the value and quantity of the capacitors can vary.
I am asking you guys as there seems to be plenty experiance soucing such things here and as there isn't a DIY spot welder forum 🙂
Chinese caps are i am guessing my best bet ?
Cam.
Cam.
