Does anyone know where I can find instruction as to how to apply the SME FD2013 tonearm lift dampling fluid? Thanks
Returns URL not valid error at least with FirefoxJesseG said:
Try this
www.diyaudio.com/forums/showthread.php?s=&threadid=104562
JesseG this is what caused the error in your link: "URL=http://]http://www.diyaudio.com/forums/showthread.php?s=&threadid=104562[/URL]"
I put it in quotes so it would print literally.
This should be "[xrl]www.whatever.com[/xrl]" note that you may omit "http://" it is understood. I replaced u in url to prevent recognition of the url link command.
YNWOAN said:I would contact SME.
It took me about 20 minutes to fix an SME once. The highest viscosity silicon i could get was about 100,000. Still worked fine.
