Help setting up an active filter
Hi!
I Need some help when setting up my active filter.
The bass/mid are some unknown hifi driver from the -90's and the tweeter is a Scanspeak 9700
By ear i got:
3,04kHz for the bass/mid (LR 24db).
2,85kHz for the tweeter (LR 24db).
Should that value instead be the same? What does the school book says?
I have also put some EQ at 1.09kHz to get rid of a nasty resonance.
Thanks for all advice!
LR4 is two cascaded Butterworth (B2) Filters.
The B2 has an F-3dB at the roll-off frequency.
When you use these to create an LR4 the attenuation at the roll-off frequency becomes -3dB + (-3dB) = -6dB
The F-6dB of an LR4 is at the roll off frequency.
It does not help your understanding by determining the F-3dB frequency for this 4pole Filter.
