Can anyone help me on finding the On-Semi replacement part for Toshiba 2sc4793? It's not easy to find 2sc4793 in the US. Thank you.
as fas as I know, the 2SC2238 is a good replacement (the 2SC2238 is more common, especially in combination with the 2SA968)
Grtz, Joris
Recitification: P.S. Woops, I didn't read it very well, you want an on-semi equivalent... I don't know one 🙁
Grtz, Joris
Hi again,
I've been searching the tables of ON-Semiconductor, using the datasheet of the 2SC4793:
http://www.bmm-electronics.nl/document.asp?document_id=466&link=Datasheets/toshiba/2sc4793.pdf, but I couldn't find a match!
Sorry!
Grtz, Joris
Sorry!
Grtz, Joris
I have
I have some 2SC4793. If you want 1 or 2, I can give them/it
to you. If you need more than 3, I'll have to charge you for that.
Just tell me your address by private-emailing to me. Praise! be
to the LORD!
James Yung
Praise! Audio
to the LORD!
James Yung
Praise! Audio
alternatives
If you are using 2SC4793/2SA1837 as drivers, you have
some alternatives: 2SC5171 / 2SA1930 also from Toshiba.
I like them better because they have high and symmetrical
fT = 200 MegaHertz compared to lower and asymmetrical
fT = 100 / 70 MegaHertz. I have them as well in 2 months
depending on factory schedule. Log on to Toshiba
semiconductors for data sheets.
Acliao,
You can use the MJE15030 from OnSemi in place of the 2SC4793. The complement of this device is the MJE15031. It's pin for pin replacement.
These devices have four times the current rating, appreciably more dissipation as well, and are rated at 30MHz. This is not so fast as the 4793/1837, but in practice, and particularly on an audio amplifier, you won't notice the difference as the emitter follower is intrinsically a very fast configuration; the slowest device on an audio amplifier is, by design, the voltage amplifier.
Hugh
Hugh
2SC4793 is at Digikey
I believe you can easily get 2SC4793 from Digikey in the US.
http://www.digikey.com
-- mirlo
-- mirlo
the qsc c3298 compliment a1306 will work perfectly
After 7 years he has probably solved his problem or moved on. 😀
7years old, but I do like the nibbles left by AKSA for us mere mortals........... rated at 30MHz. This is not so fast as the 4793/1837, but in practice, and particularly on an audio amplifier, you won't notice the difference as the emitter follower is intrinsically a very fast configuration; the slowest device on an audio amplifier is, by design, the voltage amplifier.
Toshiba 2SC4793 for stock Sanyo 2SC3467 ?
And taking advantage of it, I'd like to ask a question regarding a possible substitution for another transistor, the Sanyo 2SC3467 (pictured below), used in pair in a NAD 306 amp that is getting TOO HOT and I'd like just to be sure if the Toshiba 2SC4793 is a good candidate for replacement...
Stock: Sanyo 2SC3467 - 200V / 0.1A / 1W / ft 150MHz / Cob 1.2pF
Replc: Toshiba 2SC4793 - 230V / 1A / 2W / ft 100MHz / Cob 20pF
Thank you! 🙂
Old but still good post! 🙂7years old, but I do like the nibbles left by AKSA for us mere mortals........... rated at 30MHz. This is not so fast as the 4793/1837, but in practice, and particularly on an audio amplifier, you won't notice the difference as the emitter follower is intrinsically a very fast configuration; the slowest device on an audio amplifier is, by design, the voltage amplifier.
Thank you! 🙂
- Design & Build
- Parts
- Help-Replacement part for 2sc4793
