i have 2 Soundstream 405s amps
one for left and one for right side
the one i just got for the right side has one channel that has 20v across the speaker terminals (its one of the 4x50w channels, not the mono sun channel)
i opened it up and i found one resistor (R426) that looks burnt
and it's the only one that doesn't beep when i test it with a multimeter
to get this working, i was going to start with changing this resistor and seeing where it leads me
all the other similarly sized ones (R226, R227, R326, R327, R427, R526, R527) beep when i test them
any advice on where to source the resistor
the one next to it looks a little burnt too, was going to change that as well
or does anyone have a service manual or schematic diagram?
thanks a lot
i also have another 1000s that refuses to work bridged, works fine in stereo
and a 644s that works fine high pass or all pass, but not low pass 🙂
will start on those when i fix this one
thanks a lot 🙂
thanks a lot
thanks a lot 🙂
That kind of power on the speakers is usually shorted outputs or maybe a driver issue. Check the outputs, in many SS they are under the board (w/a bolt between them) but you should see the three pins for each. One of the legs will go to the bridging terminal of your bad channel for the two or four outputs on that channel. If any of the three are shorted to another (near 0 ohms) they are bad. Try mouser.com for parts.
If that resistor opened, the outputs in that channel are likely shorted. If only one is shorted, replace both of them as well as both 0.27 ohm resistors.
Mouser:
660-MOX2LT631RR27J
511-TIP102
511-TIP107
Email me if you want the schematic diagram.
babin_perry@yahoo.com
Mouser:
660-MOX2LT631RR27J
511-TIP102
511-TIP107
Mouser:
660-MOX2LT631RR27J
511-TIP102
511-TIP107
i had emailed you when i read on another thread you had the manual for a 405
my email is my username at hotmail
sorry i didn't get what you said
what value is the bad resistor (R426)?
and which other ones should i change?
the one next to it i wanted to change anyway (R427)
but are you saying i should change more?
can you give me values/Resistor numbers?
thanks a lot
on another note
once i have the amp working (i hope )
how would i set the gains on the 2 sides?
one amp will be left side of car (front, rear, sub)
and one for right.
how do i make sure they are level matched?
i was thinking a 1khz sine wave and measure the voltage at the speaker terminals and adjust the gain till both amps put out the same voltage
is that right or wrong?
and one for right.
you are both right
both drivers have a short on 2 pins
will order 2 resistors and 2 drivers from the link provided
thanks a lot guys 🙂
thanks a lot guys 🙂
For future reference, those are better referred to as output transistors than drivers. Drivers are typically one stage behind the outputs.
When you measure the output voltage for each bridged pair of channels, make sure that each individual channel of the bridged pair has ~1/2 of the total voltage across the bridged pair.
ok i changed the two output transistors for the bad channel (ch2)
and the 3 resistors
this is what i get when i measure voltage acorss the 5 channels
ch1 0
ch2 0.09v
ch3 -0.005
ch4 -0.008
sub ch -0.015
and the 3 resistors
ch1 0
ch2 0.09v
ch3 -0.005
ch4 -0.008
sub ch -0.015
Well i changed the 2 output transistors and 2 resistors for channel 2, which was the busted one, with the parts mentioned above
this is the voltage i read across the speaker terminals of the channels
ch1 0
ch2 0.09
ch3 -0.05
ch4 -0.008
sub ch 0.0014
is this ok?
seems ch 2 is the odd one out
prior to repair ch 1, 3, 4, and sub were working fine
i haven't tried with any speakers yet as i already fried one speaker prior to repair
so a little hesitant 🙂
ch1 0
ch2 0.09
ch3 -0.05
ch4 -0.008
sub ch 0.0014
is this ok?
ok i tested a speaker and it sounds good
but when i gave the amp a 1khz sine wave
ch 2 puts out 05v and ch 1 puts out 0.3
is that just because the newer output transistors are more efficient?
i guess i have to change those 2
and might as well do ch 3 and 4 as well as they are all rated at the same power
DC
i just re-measured after i left the amp powered on
no input signal
ch 1 0
ch2 0.08
ch3 -0.01
ch4 -0.01
Sub ch 0.01
no input signal
ch 1 0
ch2 0.08
ch3 -0.01
ch4 -0.01
Sub ch 0.01
Ch2 is a bit higher than it should be but it won't do any harm. If you replace the differential amplifier transistor (6-legged device) on the driver board, it may bring it back to an acceptable level. You can buy them from J&R electronix:
2SC3067 SANYO NPN Monolithic Transistor Pair lot 10pcs - eBay (item 380148879173 end time Mar-11-10 07:04:29 PST)
do you think if i changed out the resistors and output transistors on the other channel they would be in sync?
looks a little beyond my capabilities that six legged device
i'm just worried that ch 2 is louder than ch1
if it makes no difference in output then i'll keep them as is, it sounds fine
could it cause any damage to something else down the line?
on another note
do you do soundstream repairs?
i have a 1000s that's been messed with (radio shack resistors etc)
and i'd like to fix it
I don't know who the question was for since there were others posting in this thread. I've worked on quite a few.
When you've finished the 405s, start a new thread for the 1000s.
Mouser:
660-MOX2LT631RR27J
511-TIP102
511-TIP107
would these be the same parts for a soundstream 664
- General Interest
- Car Audio
- Help repairing Soundstream 405s
