Help please with my poorly Stasis 2
With setting up an amp you will want two multimeters to watch the behavior. You need to look at 2 critical voltages at the same time as you slowly and carefully bring things to life. One meter connected to monitor the DC offset on the output (we want zero volts), and the other meter across one of your emitter resistors in the output stage to monitor the voltage across and hence the current through, calculated with ohm's law. P1 is the DC offset adjustment and P2 will establish how much current is flowing through the output stage. But go slow and understand what is going on so that you don't burn something (or many something's) when this thing wakes up.
Reactions: TheFinisher
Thanks for the input here guys, so the resistor that has burnt is R29 on the new NP FE board, This is tied to GND normally by the normally closed thermostat and the other end is held at 9.1volts by zener D5 normally. So the standing current through it would be 4 mA for a power dissipation in the resistor of 37mW.
Has anyone here got any clues as to what has caused this or what to look for, to help out the member thanks.
When P2 is turned there is no volts across 1R0 emitter resistors, I am assuming because, the issue with R29 is holding back the drive to the base of Q6.
OK, thanks for your reply, will get the member to try that. I would have thought the zener would keep the voltage at 9.1 V, but then you would have the power loss in R9 from the -73 volt rail. Maybe both resistors should be larger wattage - any thoughts on that?
Hi Zen Mod, Mike in the US has sent me a PM where you have mentioned this in the Stasis FE thread on page 43 post #860.
You mention changing a few resistor values in relation to 80 VDC rails in answer to another member.
These were:
R8 on your schematic - R6 on NP schematic changing from 4K7 to 68K
R9 on your schematic - R7 on NP schematic changing from 2K2 to 12K
R13 on your schematic - R29 on NP schematic ( which is the resistor that has failed) changing from 2k2 to 9K1 at least 1watt.
Mike also changed Q1 (Q3 NP) from ZTX450 to ZTX457. Q2 (Q5 NP) from ZTX450 to ZTX457, Q3 (Q4 NP) from ZTX450 to ZTX457, Q6 (Q9 NP) from ZTX450 to ZTX457 and Q4 (Q8 NP) from ZTX 550 to ZTX558, which I believe are higher voltage rated. Q5 and Q7 (Q7, Q6 NP) stay as KSA1220 and KSC2690.
Can you confirm all of this and advise if any other changes would be needed,.
Many thanks for your time in this, I just want to be able to get our member there in the UK sorted as he is up to the stage of bias adjustment with the PSU all good.
Gary..
I'll try to collect some gray/grey cells tonight and do some simple math and compare of active parts V and W figures
in general, I tend to keep parts much less hot than Pa is used to; he's founder of ABFAB, while I'm just kido Pa wanabee
maybe in few decades from now I'll dare to keep my parts same hot
