HELP....Perreaux SA2 noisy phono section
My Perreaux SA2 sounds fine playing cd's but is noisy/slight hum when playing vinyl. It is noisy on MM and REALLY annoying swithching to MC.
Could it be that replacing certain caps/resistors/diodes, ect in the phono section only,.... solve this problem? Is this something a professional shop would charge big $$$ to do? I know how to solder and the difference between a cap and other parts. Help please???
That one channel is much worse does matter.
That can be fixed. The MC input is a joke, its
just MM with more gain and can't be fixed, MC
noise performance is very poor, MM is decent.
The CD input is also a joke, its no different
to the other line inputs at 110mV. The noise
difference between CD and MM is inevitable.
rgds, sreten.
Photo of inside. Should I replace the Marcon electrolytic caps shown (14) on left side (7) in center (3) on right side? Any transistors, resistors, ect. need replacing?
Will /should this clear up the hiss from the phono section?
I wouldn't replace anything. I'd swap semiconductors between
channels in the phono stage to see if the right channel problem
moves to the left, a schematic would be a great help.
Changing passive parts won't fix the intrinsic noise issue.
rgds, sreten.
No one has stopped to ask how old this unit is, whether the OP is absolutely certain there is no problem with the external wiring to his turntable, and whether or not the cartridges used meet the recommended output levels for use with this phono stage..
Some history would helpful, is this a new acquisition or is it something you have had for a while that is now showing evidence of age?
Another thing to consider is soldering skills and that PCB. Can the OP get the semiconductors out without destroying them and the board? A schematic would be most helpful.
A simple check would be to swap the left and right phono cables and make sure that the noise problem does not move from one channel to the other.
